koolkeith:
Mr Rick - Could you give a % for how much untapped potential there is in the 11's that only an amplifier like the ATC integrated could unleash. I have £2k to spend & can't decide whether to trade - in the 11's & get some 40's or keep the 11's & get an ATC integrated.
Thanks.
Hi koolkeith
Thanks for your post.
If you wish to have greater depth, scale, power, speed, detail, mid range, punch than look at the SCM40's. Your Densen amplifiers are very good and more than capable of powering and performing with ATC speakers however they can still be improved upon. The ATC SIA2-150 MK2 offers more power, the quality of the power is more potent and the performance is better.
So, if your are content with the SCM11's than i would suggest that you hold on to them and in the first instance consider the SIA2-150 MK2 which will be a superb upgrade over the B200/B310. The SIA2-150 MK2 is a teriffic amplifier and one that can punch well above it's weight. I have used the SIA2-150 MK1 and MK2 personally for a long time and they continue to sell although trying to keep one in has proven to be difficult (which i suppose is a good thing).
Anyway we've finally had another one turn up recently
(which i have not had the chance to fire up yet).
Btw, i can see the differences between the SIA2-150 MK2 and B200/B310 almost likely to remain with many speakers used (even those with a higher sensitivity).
Rick @ Musicraft
