hi i wonder if any one can help i need some advice for speaker cable and connections for an arcam a18 and cd17 with moniter audio rx2 speakers many thanks
Use decent copper speaker cable.Atlas and Audioquest do some great sounding cable which will give you a bigger soundstage than using silver. Also bass will be fuller, but it depends on what sound you want of course.
The Chord Carnival Silverscreen would be a very good choice.
I've just upgraded from that to the QED Revalation it's a superb cable and just that bit more detailed over the Chord but with solid, deep bass and smooth midrange
