Arcam a85 /p85 ×2 mono set up
Feb 18, 2015
59
Hi guy's, just wondering if any body can give any info on how to set up the arcam a85 as a pre amp and the two pwr amps for mono left and right. I've got the a85 biamped with a p85 at the moment into a pair of b&w cm5's. planning to get another p85 to run as dual mono, but have checked the manual /forums and I can't see where the other amp would fit in. The manual states that to make it a mono the link ring be removed and attached to the audio L+R out. This leaves no other connection sockets and the a85 only has a power in socket left, which states that this is to use the a85 as a power amp with the power in for a pre amp. It's all a bit confusing.
