Hi all,Yes, I know another “which TV question?”Hopefully this will give me the final decision on which one to go for.
My lounge is 10’ x 14’ approx 3 x 4 meters but will be watching across the shorter length.We will be having Sky HD installed very soon.I’ll be watching SD probably about 60/70% of the time with the rest being Sky HDAt the moment I have just a basic DVD Player, which is a Philips DVP3020, however I will be getting the Panasonic Bluray soon after though .
My ideal budget is around £700 however will stretch higher if it’s really worth it.
My short list isanasonic TX-37LZD81 @ £698.00Panasonic TX-37LZD80 @ £629.00Panasonic TX-37LZD85 @ £830.00Panasonic TH-37PX80B @ £549.00 (if ex-display) or £625.00 NewPanasonic TX-37LZD800 @ £899.00Sony KDL-40W4000U @ £720.00 (is this the same as the Sony KDL-40W4000 reviewed on here?)
Ok, so it’s not really a short list..!
To be honest though I’m tending to sway towards Panasonic, as you may have guessed.
Not too sure if it’s relevant or not, but my amp is a Yamaha RX-V795RDS
Or do I wait for the new range of Panasonics…?????
