Im just double checking to see if i have the correct settings, at the present i have the crossover set to 80hz on the amp. Im using the B&W DM602 s3 main speakers & the spec for these are:
Frequency response 52hz - 20khz
Frequency range -6db at 43hz
Crossover frequency 4khz
And on my subwoofer theres just a volume control for the line level, a upper roll off dial that turns from min to max, a slam or depth dial and a phase reversal switch and the spec for the sub is:
Frequency range 20-120hz; -6db at 20hz
Gain control range 80db
Would i be right in thinking i should set the crossover point to say 50hz via the amp? I say this as the frequency response is 52hz on the B&Ws? I could be wrong with this so im hoping Andrew or whoever else is replying to this can agree or correct me?
Many thanks
Many thanks
