rainsoothe said:OP: what speakers do you have? Music type and room size?
jipsom said:I'm not sure the Quad or Cambridge are going to be an upgrade to my Roksan. Perhaps the CXN is an option...but I'm really after a better amp than my Roksan with a DAC.
rainsoothe said:jipsom said:I'm not sure the Quad or Cambridge are going to be an upgrade to my Roksan. Perhaps the CXN is an option...but I'm really after a better amp than my Roksan with a DAC.
well you're not gonna upgrade over a K3 with 1000 pound budget 😛
A CXN will also serve as a streamer, which will elliminate the need for a laptop. If you still wanna be using your laptop as a main source, imo money will be better spent on a Chord Hugo, or Qute HD (or whatever the cheaper version is called, if it has USB). Otherwise, maybe get a nice cheap dac like Micromega MyDac and save moneys for a Hegel H160 - which does DAC and streaming too - this is what I would do.
johngw said:How about a DAC with volume control + remote and separate power amp? E.g. Matrix mini-i pro into a Quad 909 power amp. You should be able to pick up the Quad second hand and it's a great little amp.
