Hi I´m planning an Amp upgrade my current setup is 70-30 (Music-Movies) in small room 13x14 ft.
I mostly stream Classic Rock & Jazz whit Roon (No turntable, a few times CD´s) :
-Yamaha AVR Avantage RX-780, 95 watts per channel, with 2 channels driven
-Cambridge Audio CXN V2 streamer
-Pioneer BDP-320 CD/Blu-ray Player (rearly use)
-Kef LS50 (whit kef Stans)
-PSB Sub 10" Connected via High Pas to the AVR / the Kef´s are connected to the high pass out of the sub.
What i´m looking is to upgrade the amp as i think the Yamaha AVR i´ts holding me back, I know for past expirience that its better to wait an strech you budget to get the best geart, than go for something cheaper an then sell it back, my options are:
1) CA CXA81 it will match perfectly whit the CXN,
2) Also I have an option to get the CX80 *used* for half the price, my concerns here are if there are any worth imporvments in getting the CXA81 vs CXA80, I know there are some DAC improvements over one an other, but i´ts a sonic or amp improvements? I´m thinking long term here, I don´t want to sell the CXA80 in few months because I need "or think i need" an upgrade, also less important and only a piky idea is the color miss march (CXNV2 Lunar Grey vs CXA80 Silver )
3) Power Amp in price range under 1200usd and could connected via the PreOuts of the Yamaha and use the latter as a PreAmp or Connect to CXV and use the digital Preamp in the unit.
4) Roksan K3 almost 50% more $$$ than a CXA81 where i live, i will have to wait a little more time as this is out of my budget right know.
Thanks for all your advise!
