- Aug 10, 2019
- 2,556
- 5
- 0
Hello everyone,
I've been reading forums and website for long but now I decided to make the big step into the hifi world.
I'm actually using a pair of Monitor Audio AV40 active monitors connected to a X-Fi USB HD soundcard. I do like its sound even if sometimes it could be a little bit warmer.
But i'm soon going to get a real living room and so I would like to setup a system which would allow me to connect more sources than just my pc. The room where the system will be is in L shape, something like 5*5 for each square of the L. The living room will be one square of 5*5 meters with no wall on the right side.
I've actually been looking on the Boston Acoustics A26 which I can have for a good price. But I can't decide on the amp to drive them.
I firstly wanted a Denon Dm38 because it's also quite cheap but it's rated at 6ohm 30watts, so i'm quite scared that the A26 won't be driven correctly (not sure about it though).
My second choice was a Onkyo TX-8030 because you can use two pair of speakers on it, which could be helpful to add a pair of speakers in the other part of the room. But I can't find a lot of information about it...
Then there is the Yamaha R-S500 which could be nice even if I don't really like its design but sound comes first if any one tells me that it's a good choice.
My last choice is the Kenwood Ra-5000 which doesn't have 2 pair of speakers but digital in, which could be nice to plug the tv directly in it.
As you can see, I can't decide and I feel lost !
If any one can confirm that the DM38 would be enough, I would directly jump on it.
Or if you have feedback concerning the other ones.... or any other suggestions even if suggest to use another pair of speakers.
Budget is max 600 €.
Thanks in advance for your help !
Best regards,
alx
PS: Sorry if my english made your eyes bleed.
Best regards,
alx
