Amazon Fire TV Stick 4K review
abacus
927
610
19,770
Its biggest problem is limited apps and Amazon centric operation, however if you can put up with this then it is a cracking piece of kit.
I personally I would go with the Roku 4K stick (Same price) as it has a separate airiel built into the power lead for a more solid performance, as well as more comprehensive apps with no preference given too them, and while it doesn't have DV etc. most serious viewing is done by a projector, so is irrelevant anyway. (From the description in the review you did on the cheaper Roku it obviously had serious Wi-Fi problems hence such a poor picture quality)
Bill
ASK THE COMMUNITY
