Aftermarket/audiophile power cables. Surely they make a difference??
chrisrock
17
I know that this topic has been the subject of many a debate and disagreement over the years on forums. I have recently read many posts where people are seeking advice and opinion regarding power cords and it seems that there are plenty of people willing to offer less than helpful and sarcastic replies (not all but that is the general theme).
So surely these cables have to be an upgrade and actually make a difference? The reason I say that is there are companies charging a lot of money for these cables and HIFI mags such as What HIFI? Reviewing them and saying in their expert opinion that they offers all manor of different benefits.
I am am seriously considering purchasing a Russ Andrews cable as they have a 60 day return policy on them to allow it to be tired and then returned if you are not happy.
What are people's thoughts on this? Has anyone bought a power cable and been able to hear a decent improvement?
Q5
60
Duck, your head is above the parapet, it will now be a target for the naysayers.
chrisrock
17
I know. I have seen the ridicule others have got overs the years when this has been brought up. :)
chebby
1,253
26
19,220
So you know exactly where this one will go too.
chrisrock said:
So surely these cables have to be an upgrade and actually make a difference? The reason I say that is there are companies charging a lot of money for these cables and HIFI mags such as What HIFI? Reviewing them ...
Indeed, if they cost a lot and impress a journalist then I don't need to know more :)
I have used a third party mains cable (an ex-demo Chord C-Power I picked up for £35 a while ago). I bought it for it's build and shielding and 'heft' (nice thick conductors). It didn't sound any different to the freebie mains plug that came in the box with my amplifier, it just felt much safer to use. (The Quad plug felt like it was made from recycled yoghurt containers and was an offence to my senses.)
I have since sold the Chord and made my own lead using a bog standard (but well-made) 1m Lindy cable and an MK Safety Plug.
abacus
1,069
777
20,070
None of these Hi-Fi cable manufactures have ever been able to provide verifiable evidence to anyone, that their cables make a difference, which should answer your question. (Some have even had to change their marketing as they fell foul of ASA rules)
Hope this helps
Bill
Womaz
88
I have never tried different power cords in my set up, but I did do a couple of experiments with speaker cables and my USB cable
I admit to not understanding a great deal on this issue , so I did go for quite expensive cables, Tellerium q to be precise as they are well regarded. Last year I bought some cheap speaker cables and a £20 Audioquest USB cable. My opinion is that I could not hear any difference at all
Maybe in a really high end system they may do so, but I admit I am cynical
chrisrock
17
Gaz37 said:
Just consider how it could make any difference.
Well I don't really have any technical know how in the same way I don't regarding aftermarket interconnects. I just look online for reviews and trust what is being said that if I buy a better quality cable then it will improve my system. I understand the basic concept that electricity is electricity, but I'm trying to understand how companies have bing producing these for years and some people say that no matter what they can not make a difference. I guess I am hoping that a £60 or so outlay would give me some sort of noticeable improvement.
Andrewjvt
99
Is no
It cant make a difference
And yes i have tried
And no it does not change anything at all.
Womaz
88
Like you say if you have a no quibble return guarantee, try it yourself .
muljao
334
90
10,970
I agree with womaz. You've nothing to lose by trying. I don't believe there'll be a difference, but if you notice an improvement, well then it might be money well (wasted :) joke) spent
Benedict_Arnold
661
I have taken a vow never to comment on specific cables.
What I will say is that it is as much about the end terminations as the copper / silver / unobtanium wire in between. You can have gazillion quid an inch cable, but if you use paperclips on the ends...
Whether the cables as a whole makes any difference to YOUR setup depends on YOUR setup, on what YOU start out using, and YOUR ears. $10,000 a foot cables won't helps 200 quid Argos special, but they MIGHT be the final tweak in a mid to high end system. Don't believe me? Replace your current cables with doorbell wire or straightened out coathangers and see how you get on.
Buy very carefully and DONT overdo it on the cables. 10℅ of your hi-fi cost should more than cover your cables.
As for the vendor you mentioned, libel laws prevent me....
Timo
13
When I demo'ed my mains block with DC blocker, the dealer also gave me the "matching" power cable. I was sceptical whether an additional £100 was worthwhile. I compared this power cable with a box-standard one. The difference was pretty clear -- the expensive cable was the clear winner for me. Then a blind test with my wife: she instantly picked the expensive cable. Q.E.D. Needless to say that the cable stayed!
chrisrock
17
Thanks. This made a lot of sense.
chrisrock
17
Did you find the cable alone made a difference, or was it when used together with the mains block that you found the difference?
seemorebtts
66
well there's no time to waste get testing.im not a fan of Russ Andrews but they do make a difference.i use Clearer audio power cables which I find has a more balanced sound.they too have a 60 day money back guarantee.what is your hifi maybe I could recommend a plug for you as IV tried all of Clearer audios power cables.at one stage I thought I was going mad so I took all my plugs out and put the old ones back on.it sounded terrible so put them back on.I started with the cheapest plug Clearer audio make and after listening to all of them I now own the most expensive one they do £1000.if you get one make sure it's plugged straight to the mains as I found if it's plugged into an extension lead you will start to hear distortion
Timo
13
The mains block with DC blocker is a different story...
Anyway, the mains block came without mains lead. So a power cable between wall socket and mains block was needed, and that is where we tested -- with measurable results. The "winner" was from Isotek.
Why don't you go to local dealers and ask for power cables for home demo?
chrisrock
17
Thank you.
I have a Marantz PM7005 amp, Marantz CD 6005 and Dali Zensor 3 Speakers and I use qed anniversary speaker cable.
seemorebtts
66
Thank you.
great little system.i would recommend a clearer audio copper line alpha at £60.its a great starter plug and of course if you want to try something a little more expensive I would recommend Clearer audio copper line at£175 but start with the alpha.also I would recommend you get one for your amp and cd and not just one.please tell us how you get on if you decide to try.Oh also he does a copper line alpha plus at £90 but I found this one a bit wild it can really push your system and might be a bit bright for you.but don't let this deter you as you just might just like it.you can order from the Clearer audio web site he posts anywhere and he takes PayPal so your always covered and he does 60 day money back guarantee https://www.cleareraudio.com/collections/copper-line-alpha-range
abacus
1,069
777
20,070
Could you provide the measurements and test conditions you used, that way others can perform the same test to see if they can verify the results. (I am assuming that measurable means physical evidence, not subjective evidence without external influences removed)
Bill
macdiddy
87
I normally stay clear of debates like these because we get the same old arguments from both sides which lead to 96 pages of replies that get ever so boring that we never find out what the outcome is (or do we even care by this point).
but I do have to say this, everytime someone asks a question on this forum regarding cables whether they be audio, video, mains etc, you pop up with the same copy and pasted reply saying that "it doesn't matter" or "all cables are the same" and now you add to that with your request that Timo provides "measurements and test conditions", why should he after all he said the even his wife noticed a difference between a standard cable and the £100 one he came back from his dealer, are you calling them both stupid because that's what it sounds like.
If you have nothing constructive (or new) to add to any post regarding cables then I suggest you go elsewhere, because to be frank your sarcastic replies are starting to get on my wick. *aggressive*
drummerman
540
Don't know if they make a difference but my aftermarket mains cables sure look sexy :).
AUDIO FRIENDLY SHIELDED POWER CABLE (ebay)
Sorry, can't post links.
Don't they look cute? Not expensive either.
Treat yourself. You know you're worth it.
