I mentioned in a post before that I was looking to upgrade. Possibly an all rega system. As my sources are Arcam 1cd player and a Yamaha HD1500 (Hard drive recorder) which I will be keeping i was wondering the value of a another cd player. I've seen mentioned a Rega DAC in this forum producing good results.
If i was to use the Rega DAC and the above sources as transports would their sound change to Rega characteristics or would they produce an unpredictable result. I believe the Yamaha internal DAC can be switched off for an external to be fitted.
