Hi All,
I'm looking at buying the Marantz PM7000N and Q Acoustics, either 3030i or 3020i. I see the amp puts out 2x 60W into 8 ohm or 2 x 80W into 4 ohm. The 3030i has a min impedance of 4 ohms, average 6 ohms and recommends a stereo amp between 25-75 W. Is the amplifier too much for these speakers? Do I risk damaging the speakers because of the slightly higher wattage/ohm output on from the amp?
The reason - I'd like to invest in a slightly better amp now, with the goal of keeping it long term and possibly upgrading to bigger speakers later. The room is medium sized, so I don't need massive speakers for now. Any other recommendations for speakers around the same size to go with this amp?
Thanks for the advice,
B
B
