Coll said:Who as actually got one.
What do you think of it.
What kit are you using it with.
I am considering one to use with my 8200CDQ and Troels Gravesen designed speakers.
Esra said:Why not Audiolabs own amps like some sec. hand 8200MB?They are pretty good after they run in (up to several months depending to how often you use your system).won´t be a problem if sec. hand and cheaper;there are some good deals so you can sell with minor loss if you don´t like them with your speakers which I don´t know . +1 also for Hypex although they need also some weeks to settle in if you can do the easy diy.These should be good for almost every speaker.
iQ Speakers said:Coll, could it be the Audiolab you are finding bright, as Burnsie post? and not the DIY amp?
Coll said:iQ Speakers said:Coll, could it be the Audiolab you are finding bright, as Burnsie post? and not the DIY amp?
No previously I had a Crown XLI1500 and it was not bright then.
Burnsie said:I love my Abrahamsen amp but when I first got it and used it with an Audiolab 8200cd and it was a horrible match, very, very bright and fatiguing. I was using Spendor SA-1s at the time.
Before you take the plunge make sure you can get a listen to the combination somewhere.
iceman16 said:Coll said:iQ Speakers said:Coll, could it be the Audiolab you are finding bright, as Burnsie post? and not the DIY amp?
Coll, I suggest listen to Arcam A29 and as many amp you can in that price range
JMac said:The arcam P49/A49 is on my list of potentials and I have the same drivers as you i believe Coll?
DocG said:I think you can't go wrong with the V4.0 UP: 140 Wpc into 4 Ohm...
Having said that... Since you're into DIY: ever considered building a Hypex NCore power amp? You can have all necessary components for under £750, and you could go for a pair of monoblocks. Works best with XLR (which the CDQ has). 400 Wpc of clean power into your 4 Ohm speakers...*bomb*
Coll said:DocG said:I think you can't go wrong with the V4.0 UP: 140 Wpc into 4 Ohm...
As it would seem that the Abrahamsen is a bit bright with the 8200 CDQ how would the ncore be are these smooth amplifiers.
I have thought of this route but did have a B& O class d and did not like the treble at all.
iQ Speakers said:The Abrahamsen is not the problem as Burnsie discovered. They are very neutral feed it something bright it's going to amplify it like any decent amp. That's what they are designed to do. What they don't do is colour anything. The Audiolab is the problem here feed it into a Hypex amp you will have brightness.
iQ Speakers said:The Audiolab is the problem here feed it into a Hypex amp you will have brightness.
It is nonsence as Coll has not get the combination yet. We are going by Burnsie experience. Below is his quote.Esra said:iQ Speakers said:The Audiolab is the problem here feed it into a Hypex amp you will have brightness.
Total nonsense.Nothing is wrong with the Audiolab CDQ,don´t worry.
Burnsie said:The problem with the sibilance was caused by the Audiolab, I ended up buying the Linn Majik DS and I am really happy with the sound and it made me realise what a cracking amp the Abrahamsen is. I had a good session yesterday with the CD player(UP version). It is built as well as the amp and the remote control is exactly the same, it sounds very good for the price(£530 delivered) although the Linn does beat it hands down with revealing the finer details.
The SA-1s with the Abrahamsen does sound good but upgradeitis is on me and I am starting to look for new speakers and hopefully within the next month I will start to demo some to see where it takes me.
