- Jan 16, 2013
- 661
- 3
- 0
If your turntable has an integrated Phono pre-amp, or if you are using a separate Phono amp, do NOT Connect your turntable directly to the Phono inputs on your amp.
Amps with inputs marked "Phono" usually have additional internal pre-amps within them, and if you connect a previously Amplified signal (amplified by the turntable or the Phono pre-amp), you're likely to blow your amp.
Same goes, I guess, for turntables with integrated pre-amp and external Phono pre-amp boxes.
Lesson learned the hard way. :-(
