krazy_olie
- Aug 19, 2011
- 6
- 0
- 0
FrankHarveyHiFi said:My take is that, if it was there before, then it should still be there after, whether I can hear it or not![]()
Certainly a logical approach, though speaking from an engineers point of view it can sometimes cause more problems than it solves. For a very loose example the hardware that I work on doesn't process things you can't see and massively improves efficiency. In a real world scenario you put resources in to producing things that are irrelevant you inevitably pull resources away from something that is relevant.
This isn't the best example though of that as I stated above I don't think the benefit of a 40khz response has anything to do with hearing 40khz... unless you are a dog.
I'm not an acoustics expert it is quite possible that frequencies above 20khz are used in some way, certainly you won't hear a 40khz tone but I don't know enough to say that it has no effect at all.
Also re the mp3 comment above. I think it has more to do with the fact that the basis on which mp3 makes it's decisions about what to throw away are not perfect and an approximation. Naturally the more bits you give it to play with the better it sounds. A cd will not have anything higher than 22khz in it so mp3 certainly won't top that.
