tomlinscote said:
Two 8 ohm speakers connected in parallel will have a combined resistance of 4 ohms if that is what you are asking but for a pair of speakers one to the left and one to the right channel they remain 8 ohms each. This is a nominal figure and will change with the sounds given out, some manufacturers quote a min figure too so you can see how low the figure goes in case your amp cannot cope with it. For example Quad quote a nominal figure of 6 ohms but say that this can drop to 3.5 ohms.............
Tommo
Hi Tommo,
what a coincidence you give the example of Quads. I'm looking into their ESLs, which seem to have a benign impedance curve (very benign for ESLs), with a nominal impedance of 8 Ohm, and variation of 4-20 Ohm, making them an easy load for an amp. In a
Hifinews review however, the lab report measures (and I quote) "a minimum modulus of 2.7 Ohm at 20 Hz. Impedance phase angle at low frequencies is high enough to lower the EPDR (equivalent peak dissipation resistance) to a minimum of 1.4 Ohm at 69 Hz, but as the ESL-2912's impedance will be level-dependent at LF, the dip to 3 Ohm modulus at 7.5 kHz and to 1.6 Ohm EPDR at 1.1 kHz are more relevant and suggest a moderately difficult amplifier load." (End of quote). Any idea what this is all about? Do Quad give wrong specs? Or are these different things altogether?
BTW: just heard the ESL-2805s, and they were incredible! I was high for the rest of the day!
