Hi all. I’m running a budget home theatre setup, and am using an Acer H6810 DLP projector at 4k (pixel shift) from an XBOX series X. I’ve got HDR and 10-but colour enabled on the Xbox, which seem to be the optimal settings for the projector.
My issue is that it keeps dropping sync (no signal), or taking ages to sync when I turn the projector on or switch input. The projector is about 5m from the screen, and am using a 10m HDMI cable that says is rated at 4K/60. (I’ve tried two different cables of different brands). If I run the projector at 1080p with HDR turned off I don’t seem to have any issues.
My suspicion is that the cable is too long and it’s struggling in sustaining the data throughput; any recommendations on using HDMI over Ethernet or optical based on 10-15m length?
I’ve checked for projector firmware updates but can’t find any available. I’m using an SPDIF splitter (extractor?) between the Xbox and Projector as I need optical output for my audio setup. Has made no difference when i add or remove the splitter.
I haven’t tried connecting the projector directly to the Xbox with a short HDMI cable purely because it’s a headache to remove the projector from the ceiling mount. I realise this is an obvious test but I’m fairly confident the cable length and signal degradation is probably my issue. What’s everyone’s thoughts? Cheers
