2 channel amp for music instead of Sony 1050 av receiver?
PAAAUDIO
I have just tested out my birthday present a Marantz CD6006 and am surprised by how good it sounds over using my Xbox One for playing cds.
Can I get a similar improvement by getting a 2 channel amp instead of using my Sony 1050 av receiver?
If so what would people recommend?
I like Vocal music including Andrea Bocelli and Mariah Carey.
PAAAUDIO
Yeah, I was thinking about the Marantz PM6006 but wasn't sure how well it would drive the Kef Q500 speakers or if it's good with vocals. I'm guessing it would be fine.
muljao
334
91
10,970
Generally stereo amps willd dp a better job obviously within certain realistic budget restrictions. The marantz PM6006 seems the natural choice,(your speakers at 8 ohms and 87db sensitivity should be driven easy enough) but the Onkyo a9010 gets as good reviews. It does not have a built in dac, but not sure you need it with the sony receiver.
If it was me I would try and spend a little more, the q500 speakers are slightly higher end and maybe a better amp might be worth it.
PAAAUDIO
Thanks for the reply.
I will look into getting the Onkyo amp. I was wondering about spending a little more so will try out both options soon.
Getting the Kef speakers recently has reminded me how much I used to love music and especially CDs.
seemorebtts
66
if you want something a little bit special the Arcam a19 will get dancing a bargain at £500
PAAAUDIO
I will try out the PM6006 then. I do like the matching styles and the finish of the CD6006 was also a lot better than I was expecting.
