Hi everyone.
I figured this would be a good place to get some turntable advice, so here I am. I have a few questions, and as this might get a bit confusing, I'm going to try and break it out:
1. I have a ProJect Essential 1 - bought in 2011 - which I've since upgraded from an Ortofon 3E styli to an OM10.
It's served me well, and sounds great with both my old Denon mini Hi-Fi and my Q Acoustics M4 soundbar. However, my phono preamp is only a cheap Behringer PP400 which produces a bit of hum at higher volumes.
I also seem to get an awful lot of static from using an anti-static carbon fibre brush before playback; I can tell because I almost always hear a 'tttsssssssssssss' noise through the speakers as I pull the record away from the spindle. Is this normal? I've just learnt to live with it.
I also, on occasion, get inner groove distortion. But this only seems to be on select records, which are likely to be naff pressings to begin with.
2. So, should I:
A) just get a better phono preamp and stick with the OM10. If so, which preamp?
B) sell the TT and pick up the quite lovely looking Rega Planar 1 Plus which includes a built-in preamp (saving me hassle)?
C) sell the TT and get the Rega Planar 1 and a new preamp for a similar price?
D) ignore Rega, and get a better ProJect deck. If so, which?
The Rega comes with a Rega Carbon cartridge and styli, which I hear is a bit of a ball ache to upgrade unlike the Ortofon OM range. But I've also heard it sounds fantastic, so I'm unlikely to need to upgrade it for casual listening anyway, and if I were to, it would only be the stylus I'd upgrade.
My budget is £350 max.
One last thing, I use a rubber turntable mat. Is a cork one likely to make any difference?
If you read all this, thanks for your patience!
2. So, should I:
