Yamaha RX-V1800 help!! Pls!!
sta99y
137
Hi all,
I have just got myself a mint 2nd hand RX-v1800 and wondered does anybody know if it will definitely do HDMI passthrough ?? I won't get time to setup till next week.
Also was wondering if it does arc or is that my tv that handles that??
Many thanks
Darrell
sta99y
137
MUSICRAFT said:
Hi sta99y
Nice one :)
There is no HDMI passthrough of ARC with the RX-V1800.
All the best
Rick @ Musicraft
Hi Rick,
yes i figured this out now but its ok,
i have run a 2nd hdmi up to tv for virgin hd, on memory 4 i have HDMI set to other and not RX-V1800 so this way i can switch amp on but have tv sound on only,only drawback to that is that the amp wont decode hd audio, its just PLII in this HDMI mode
Its fine tho because when im around i use the other memory setups where the HDMI is set to 1800 so its all singing etc...
its a capable amp you think?
not a huge step up from my old 2400 but maybe in modern HD times,
thanks for youre reply.
PS do you think an antimode is a worthy upgrade?
Darrell
