Is it worth buying a separate preamp to replace the one on the Yamaha? Will it improve the sound quality noticeably?
stevebrock said:It's all about balance really - I think your phono stage in your amp is of good enough quality to match your turntable - what cartridge do you have ?
If you had a £1000 turntable then maybe a seperate phono stage would be better especially if you £300 cartridge on the turntable.
maybe improve your cartridge first ????
