A admin_exported New member Aug 10, 2019 2,556 5 0 Jun 17, 2009 #1 Got a Pioneer DV-717 dvd/cd player for free today is it worth using it as a cd separate if i hooked it up to a amp ? or should i dump it ? Got it new in a box unsold !
8 8009514 Well-known member Jan 7, 2008 72 0 18,540 Jun 17, 2009 #2 You can dump it in my direction if you like!
A Anonymous Guest Jun 17, 2009 #3 that good then compared to today ? i know it was expensave when new. Seems ill keep it so the retail store i work for had 3 i saved this one from recycle.
idc Well-known member Jan 2, 2008 1,167 142 19,370 Jun 17, 2009 #4 What digital/optical outputs does it have? You could consider using it as a CD transport and connect it to a DAC and the DAC to the amp. You are likely to get better CD sound that way than purely using it as a CD player connected straight to an amp.
A Anonymous Guest Jun 17, 2009 #5 It has digital coax and fibre optic connections which should i use ? optical is ment to be better right ?
John Duncan Well-known member Jan 8, 2008 2,035 34 19,720 Jun 17, 2009 #6 What happened to the other two?
