World Domination Part One - Learn to solder
Watching those videos has made me realise I was doing it completely wrong. No wonder I had trouble. 🙁 Now I can't get me tip clean.
gpi:Watching those videos has made me realise I was doing it completely wrong. No wonder I had trouble. 🙁 Now I can't get me tip clean.
You can buy a little tin of tip cleaner from a well known high street electronics specialist shop - you know the one, sounds like a holiday camp!
It is really important to keep your tip clean. If you have variable temperature control, don't use too high a temperature, that'll make keeping the tip clean much harder.
idc:
I am going to get this to shove my tip into.......
http://cgi.ebay.co.uk/SOLDERING-TIP-CLEANER-BALL-NO-NEED-FOR-WATER-NEW_W0QQitemZ220402493616QQcmdZViewItemQQptZUK_Home_Garden_PowerTools_SM?hash=item33510328b0#ht_1079wt_939
I am defintely getting better at tinning, I now have a few where you see the cable twist and it is all shiney. I am also going to get a helping hand stand with magnifying glass. Both can be had off ebay for under ten pounds.
Maplins do helping hands for around £9.
You'll find that you may melt the insulation on the wire when heating up the conductor. The solution is to use wire with a teflon coating...or heat shrink.
My soldering station is complete. Nothing has cost more than £10. The brilliant wire stripper cost £2 and makes quick work of all wires. The tip cleaner means I do not lose heat when cleaning the tip on a sponge. The helping hands is ideal for gripping phonos and other metal but it crushes cable and bites through the insulation.
