I'm experiencing regular cutouts when trying to play spotify through my airport express and it's reeeeally starting to grate now. Usually the first song i'll play will be fine but after that i get cutouts every couple of minutes or less.
I tried turning off the windows zero configuration thing but then airofil doesn't seem to recognise my express. Also, when i disconnect from the express manually i can't seem to connect unless i turn WZC back on. Is there something i haven't done in order to be able to connect without using the WZC setting?
