will it do 7.1.4
markyboy156
203
hi all
is it possible that the samsung k950 will do 7.1.4 sound
using a additional 2 speakers i was reading on amazon some guy said
has anybody tried to/ or can you add additional speakers to this successfully as an example add radiant 360 r1's
to side of room
answer;
the installation manual says it can connect up to a samsung multi room audio system it looks like you connect it to a
wifi enabled device that controls some other speakers if you can download the manual from samsung site it has some explenations
can anybody please verify this is correct
if so what do i need to buy and what speakers would work very well with the soundbar thanks
