Will i get better sound quality?
johhnycager
6
Hi.. i bought a ATH-MSR7GM and i planing to buy a DAC,
"AudioQuest DragonFly" for example... Will i get clearer sound whis that DAC? or not?
Al ears
johhnycager said:
Hi.. i bought a ATH-MSR7GM and i planing to buy a DAC, "AudioQuest DragonFly" for example... Will i get clearer sound whis that DAC? or not?
I guess it will depend what you are going to connect to the DAC and what type of files you're playing on it.
MajorFubar
690
8
What Al Ears means is what are you plugging them into? Phone? Tablet? PC? Mac? And what make and model? No one can tell you if a Dragonfly will give you better sound without knowing what device you are using.
johhnycager
6
oh, sorry! forgive me for my bad language, i'm not an american.
I decided to buy a DAC for my pc (normal pc)... because my pc has poor onboard sound card...
for that i decided to looking for a really good DAC to get clearer sound quality
dalethorn
2,222
I decided to buy a DAC for my pc (normal pc)... because my pc has poor onboard sound card... for that i decided to looking for a really good DAC to get clearer sound quality
The DragnFly v1.2 is very good and the new DragonFly Red should be even better - ideal for laptops, and should drive your AT headphone just fine.
Al ears
True to a point. It all depends on what type of music file you are trying to play.
