Why do we need the next format of uhd or 4K if you like on a disk why not a memory stick like usb.
they are easy to use, can't be scratched and take up less space
The_Lhc said:Costs too much to produce at a guess, discs are cheap.
daveh75 said:A better question would be why a physical format at all.
expat_mike said:The_Lhc said:Costs too much to produce at a guess, discs are cheap.
It is not just the discs that are cheap, but also the factory time required to get data onto the disc/stick.
For discs:
The retail cost of a recordable bluray disc is about 50p.
http://www.amazon.co.uk/TDK-Blu-ray-Disc-Spindle-Printable/dp/B002RT85RW/ref=sr_1_1?ie=UTF8&qid=1446302407&sr=8-1&keywords=blank+bluray+discs
The cost to the music producer will be less than that, plus the music data is imprinted onto the disc when it is pressed, so the physical disc arrives at their factory with no additional operations needed.
The overall cost to the music producer for the physical bluray disc, containing the music will be of the order of pence.
For memory sticks:
The retail cost of a blank 32 Gb memory stick is of the order of 8 pounds.
http://www.amazon.co.uk/Kingston-Technology-DataTraveler-Generation-Flash/dp/B00C5K8E1A/ref=sr_1_1?ie=UTF8&qid=1446302733&sr=8-1&keywords=32+gb+memory+sticks
The cost to the music producer will be less than that, but they still have to get the music loaded onto the memory stick. Anyone who uses a computer will know that it will take several minutes to load the 25Gb of data onto the memory stick. This time represents the bottleneck on how many copies of the music can be produced each day, and leave the factory door. The more discs/memory sticks that leave the factory, the lower the unit operating cost, and the larger the profit.
The upstream costs of initially recording the music, and downstream costs of marketing etc will be the same, whatever medium is used.
But overall the music producer will always see optical discs as the cheaper solution.
f1only said:The price for a 25gb BDR may be cheap but a 4k film is going to be more than that 75 to 100gb if the quality is good & they are not exactly a common size at present where as a 64gb usb is. Or you could download it as a file, as someone else suggested, this may take a couple of hours depending on your internet connection.
I've just converted a download (I HAVE PAID FOR) from 1080p to 4K as an experiment (it took 4 hours on an 4th generation i7 gaming pc with a fast samsung 1TB ssd drive & 16gb of Hyperx ram) & the 4k file with 5.1 surround is 4 times the size of the original & to be honest was not worth the time or effort to convert... does NOT improve picture or sound quality either.
expat_mike said:Don't get distracted from the bigger picture - even if I have underestimated the cost to the manufacturer of the optical disc, by a factor of 10, it will still be cheaper than using a memory stick.
Making the files available for download will be cheaper still, but this scares the music/film producers. There is a section in the book "The longer Long Tail" that explains the economics, and that the music/film producers are ultimately fighting a losing battle to hang on to physical media. This is not because of consumer rights, but because it has already been demonstrated that they will make less money, if they refuse to use the download route. Ultimately the shareholders will win the argument, because they favour maximising profit.
How can they release UHD blu ray discs without the players in the market??gel said:Are there any Ultra HD Blu-Ray's on Amazon? Can someone link? Ta.
f1only said:I've just converted a download (I HAVE PAID FOR) from 1080p to 4K as an experiment (it took 4 hours on an 4th generation i7 gaming pc with a fast samsung 1TB ssd drive & 16gb of Hyperx ram) & the 4k file with 5.1 surround is 4 times the size of the original & to be honest was not worth the time or effort to convert... does NOT improve picture or sound quality either.
You could at least operate an HD TV.MajorFubar said:It reminds me of when HD TVs came out...didn't they too appear before BD players/BDs/HD TV channels?
Jared Rapsey said:Don't know memory cards not that expensive plus they will charge £25 plus for udh bd movie when they come out anyway
MajorFubar said:f1only said:I've just converted a download (I HAVE PAID FOR) from 1080p to 4K as an experiment (it took 4 hours on an 4th generation i7 gaming pc with a fast samsung 1TB ssd drive & 16gb of Hyperx ram) & the 4k file with 5.1 surround is 4 times the size of the original & to be honest was not worth the time or effort to convert... does NOT improve picture or sound quality either.
What were you expecting?! You can't put back what wasn't there to start with by upscaling the resolution. Do you think if you upscale a tired old 240p video from a ten year old smartphone to 1920x1080 it's suddenly going to look look HD? True 4K films were shot/rendered at >=4K to begin with, not upscaled from quarter the resolution.
gel said:We need it and we need it now!
simonlewis said:Now CES is underway does anybody know when we hear about 4k blu-ray. *scratch_one-s_head*
