Which speakers?
Feb 9, 2016
Hi everyone
I have just been put into the fortunate position of suddenly coming into possession of 4 pairs of speakers! Fantastic, but I only need one pair. Not being an audiophile, I would really appreciate some advice. How would you rank these speakers? Which pair should I keep? I'll be using them with a Technics SU-VZ320 amplifier, and will mostly play rock/pop/jazz/classical records from a Beogram 1202 record player, as well as playing music from my laptop/phone via the aux input.
Options are:
1.Wharfedale Linton 2
2.Mordaunt-Short MS 3.10
3. Monitor Audio Bronze BR 2
4. Nucleus 1 (presumably TLD, although it doesn't actually say)
Many thanks in advance!
Jack
Hi Jack,
Of the speakers you listed I would rate in this order
1. Monitor Audio Bronze BR 2
2. Mordaunt-Short MS 3.10
3. Nucleus 1
4. Wharfedale Linton 2
Others may have a different opinion.....
May be a case of trying them with the rest of the set up because a lot depends on placement and amp matching....
The_Master66
Jack Davies said:
Hi everyone
Options are:
Jack
Just listen to them then you'll know. My bets are on either the BR2's or the Lintons.
We have no idea of the size and set-up of your listening room so cannot really comment.
