Which speakers?
gsyx123
37
Hi guys, :wave:
It's finally time to replace the Denon m30 cd player & Mission speakers for our bedroom. Decided to go for the Marantz MCR610 because i want DAB, CD & airplay. My dilemma is the speakers! i can get a package deal with Wharfdale Diamond 121 for £50 more than Q Accoustics Q2020i (Black or only £20 if white).
For bedroom use, which would you pair the Marantz with. I don't change very often, but like to think i've got the best system for the intended use (wifey hates it when i drone on that i should have bought so and so...). Ideally i need to hear them for myself, but that isn't going to be easy due to work restraints.
So guys, if you were spending your money what would you buy?
Thanks in advance
gsyx123
37
Anyone?
Have also been offered the Monitor Audio Mass, but it looks like a surround speaker to me!
Could the MA BX2's be a better choice?
Lo Fi
28
I used to have the Marantz first with MA BX2 and then with MA RX1 speakers both were great but obviously the RX 1s were better
