Going to treat myself to a Denon DM 41 dab.The reviews recommend Denon SC 41 speakers.Anyone got this or any other recommendations? Thanks
Good for you, you'll be glad you did.Going to treat myself to a Denon DM 41 dab.The reviews recommend Denon SC 41 speakers.Anyone got this or any other recommendations? Thanks
That makes sense.Hi,thanks for replay,got to keep to bookshelf speakers,lack of floorspace....
Thanks for the input.After various reviews,yours included I am now leaning towards the 3020 I.Thanks again.You could look at the q-acoustics 3020i or the newer 3030i.
I've got a pair of the 3020i and they punch well above their cost. There only slight downside is their bass extension. It's ok, but not brilliant. For me they're fine as using on a bookshelf in my study, so don't need huge amounts of bass.
It's bass is an issue, look at the new 3030i, which world be my upgrade for my current pair. They've taken bigger bass drivers from their 3050i towers and used these to create a pair of bookshelves that go down to 46kHz
One warning: Both speakers are very deep.
I've got mine directly on IKEA Billy shelves, no stands, and they sound great.
Glad to be of assistance.Thanks for the input.After various reviews,yours included I am now leaning towards the 3020 I.Thanks again.
