which phono stage
evo6tme
31
Just gote myself a tag (audiolab) 8000 Q preamp and a pair of 8000 M's but now need a phonostage . I have never bought a phono stage before so dont know were to start. Will be using a gyrodek se /techno arm . and kef 104.2(raymond cook SE). I have a buget of £500 and dont mind SH . Oh yeh needs to MC input ???
What should i be listening too??
DIB
165
34
18,620
Seeing as you've gone down the Audiolab road, why not plump for the Audiolab 8000PPA phono preamp? Synergy and all that.
Seems to fit the bill and under your budget.
http://www.superfi.co.uk/index.cfm/page/moreinfo.cfm/Product_ID/3841?gclid=CN_AwcPIzqoCFdFc4QodqhX60w
DandyCobalt
203
I followed advise on this forum and bought a Trichord Dino phono amp, and Power supply from fleebay. Haven't looked back. Superb sound and has made me buy loads of vinyl now.
(MM and MC and lots of things to adjust if you really want to)
ps. I think Michell designed the Trichord Dino.
DIB
165
34
18,620
Seeing as you have gone down the Audiolab road, you could consider the matching Audiolab 8000PPA phono amp, which fits the bill for you (currently £480 from Superfi).
Either Project Tube Box SE II or the Phono Box SE II come to mind, both are superb for the money. I'd try a home demo of a phono stage before you buy one
My advise would be to look at the Tom Evans Audio Microgroove which, in my opinion, is miles better than the Trichord Dino. I have used both before. The Microgroove can be set to work with any cartridge and can be found hers:- http://www.audioelevation.co.uk/CartV3/Details_options.asp?ProductID=311
