which phono cable interconnects for headphone amp?
Hi, Ive just purchased a Graham Slee Solo headphone amp and wanted to get some advice on which phono cable interconnects to use to link up to my Primare CD31 Player. I was thinking to use Chord Company Anthem2 phono cables, but I only have a budget of say £100 - £150. Secondly, which is the best way to connect the Headphone Amp? As mentioned, my choice would be to connect directly to my CD Player, but I have read in the instruction manual that it can be connect ed to the Pre Amp through Tape loop Out. Thanks.
I think what you should do is go to Head-fi.org where they're crazy about headphone amps and should be able to guide you with what you need in terms of the different types of cables available for interconnects. Just my two cents..
