Look sorry to be a pain but I nearly have my system sorted and need advise on these last three questions.
Andy sorry it should read Arcam Muso/Logo speakers (860 quid). This was in ref to early post were you recommended the tannoy F1 or MA BR2 over the Kef3005SE. The Muso/Logo was offered by the agent as alternative to the KEF`s as stock still has not arrived. Neither has the Tannoy or MA yet there supposed to be here mid month. As recommended (by choice) I went down the CD + HDDVD route until the blu-ray cost and avilabilty is sorted. Taken some time but now have the Onkyo SR605, Marantz CD 6002 (165/-) and Toshiba EP35 for quid 119/- Just got the Onkyo and marantz out the box and found the power plugs are two pin. Although Dubai is three pin etc same as UK this seems typical with most products. The Onkyo power plug is wired internal of the machine the other end has a two pin plug while the Marantz comes with a loose lead which both ends are two pin. Will this be a problem if so what is the solution.So what's your advice on hook up, speakers and power cables?
