Where to buy SONY BRAVIA KDL-40W4500
Does anyone have any idea where i can buy a Sony KDL 40W 4500 new?
Looked everywhere but no luck in finding any.
You are really going to struggle now as its been quite some time since Sony UK were able to supply any.
If it helps, its replacement, the KDL-40W5500/5710 is a better set anyway. The Bravia Engine 3 is significantly better at handling standard definition content and the audio performance is improved as well. There are some good package deals around at the moment, with the BDP-S350 or the new BDP-S363, so well worth looking into.
Alternatively there are some great deals around on the KDL40Z4500 which is significantly better than either.
Thanks matthewpaino,
I went and had a good look at the KDL 40Z4500 and it blew most of the other sets away!
Thanks for the recommendation as i have now made my mind up after many long weeks of looking! Should hopefully get this on order over the next few days.
