Questions re Samsung QE65S95F TV
dcanham001
88
Hi all,
I'm considering the Samsung QE65S95F for my next TV, however had some queries which I was hoping some owners of the TV could help me with. I'm in the UK if that makes any difference to the answers. I'm finding it hard to get information on the Connect box.
Can anyone provide the dimensions of the Connect Box that comes with this particular model?
Is it possible to wall mount the Connect box?
What is the length of the standard cable between the Connect Box and TV?
Can anyone share an image of the Connect box for this model (so I can see where the cable ports are in relation to each other and the box itself)
Thanks for any replies.
Hi all,
Contact Samsung
Hi all,
I had the Samsung 65S95D for a while and the connect box is quite a lot slimmer than it used to be. It can and was attached to the back of the TV when I had it on a table stand. I am not sure with wall mounting.
What are you planning to do with it? Is it wall mount it? And you want the connect box wall mounted?
