Does anyone listen to Spotify through their TV?
Holt
1,532
580
2,570
I have just started to do it on my Sony Bravia 7 but I am a bit worried about screen burn which is even possible on a Mini LED TV. My Sony does have a dark mode that means the screen goes black and it just has a little logo of the song you are listening to in the corner to help prevent screen burn. Is that sufficient, would you use your TV in this way? Thanks
Edit, forget that I just asked AI instead and it said it is sufficient on a Mini LED but not on an OLED TV.
Mini LED is just the backlighting, the panel is LCD which does not suffer from screen burn. There can be temporary image retention, caused by charge build-up in the liquid crystals, if a static image is displayed for a very prolonged period and at high brightness but, that will most likely fade away.
Reactions: Holt
Thanks mate, I just edited my first post too. Cheers.
