- Aug 10, 2019
- 2,556
- 5
- 0
I've been using my airport express to stream sound from itunes and spotify to my amp, but have had lots of problems with dropouts etc. I finally seemed to fix the regular dropouts using something that i downloaded called windows zero shutdown, which turns off WZC once it has connected to the network, but now the sound seems to drop out completely after about 5 minutes and i have to reconnect the whole network. I've recently upgraded to spotify premium and if i can't fix the airport express problem i think i'm going to switch to wiring my laptop to my hifi.
What would be the best way to connect my laptop to my hifi? Is it still possible to put my laptop to use by connecting my laptop via into the AE, using the AE DAC instead of the laptop?
Thanks!
Thanks!
