Tidal Connect on PC intermittent seeing streamers to connnect
Witterings
873
582
11,770
My Tidal connect is very intermittent on seeing devices, the worst and the one I use the most is my Node.
Sometimes you'll click on the speaker button and it only shows you the laptop / PC's speakers, others it'll show only some of my WiiM's, other times all of them and occasionally it shows my Node as well.
It can be as fickle as you click and it shows them all but minimise it again, click on it again 15 seconds later and you only see the onboard speakers.
This is with 2 laptops (one brand new) that are wireless and also 2 x wired PC's, I've tried it on both Private and Public Network settings ..... however it works flawlessly with any mobile devices both Apple & Android so it's definitely a Windows issue.
Anyone similar experience and or ideas for a fix.
As a side note, Spotify, and Qobuz on Windows can both see all the devices
When you go into file explorer and click network do all the connected devices show up? is it could be a Tidal problem, so check to see you have the latest version.
If you cant see all of them then restart the router, which will clear out the cache.
Hopefully this will sort things out.
Bill
Bill
Cheers for that .... I know the WiiM devices have always shown up on the network and can see them all now, I don't remember ever seeing the Bluesound devices in there although I've never consciously looked before and you can't see it from there now.
I've also just tried Tidal from the machine I'm at, initially it saw 2 out of 4 WiiM's and no Node, then went to all the WiiM's but still no Node so minimised Connect, went back into it 20 seconds later and Tidal can't see any of them but they're all still visible in the network.
I also have the BlueOS App on he computers and they can all connect fine, I'll try the router reboot just in case but it's been restarted several times since I've had this issue so wouldn't have thought it'd be that.
Bill
If they're not listed in the network (I have re-booted router), any ideas what else I could try, I was thinking about giving them a fixed IP to see if that makes a difference.
Certainly all My WiiM's and Arcam streaming Amp .are listed under Media Devices.
Try re-installing the App to see if this solves the problem, or if you are using it through the browser, try a different browser.
If none of the above works, then best to contact Tidal as its probably a problem on their end.
Bill
Something to check... Do you clear your song queue when you finish a listening session? I have noticed (particularly with Spotify actually) that if you have a connection that wasn't terminated, the playback device doesn't always appear, probably because it's in use by another device and doesn't advertise itself as available on the network.
This could be unrelated to your issue, but it's something i've had to tell the members of our household in order to avoid minor frustrations when switching between streaming users...
In the end I changed my whole network over to a mesh system .... the last part of which was done literally yesterday when an engineer from my ISP came and removed my router modem to fit a bridge modem ... early days but it seems to have resolved it for now although a few times in the past I've rebooted everything and it worked for a day or so before not showing up again.
Before yesterday I did find that using MLO they also showed up so had gone that route.
Fingers crossed though as everything is now on the same network it'll be OK although I can't se why Tidal had such a problem when Amazon Music, Spotify and Qobuz all worked without any issues.
