What speakers
I have the following: Project Debut TT Cambridge Audio azur540a amp Cambridge Audio azur540c cd TDL Nucleus KV1 speakers bi wired I am looking to upgrade the system probably getting better speakers, can you recommend any that will go with the system? Also how would you improve my system?
Depends on how flexible your budget is? for standmounted speakers I'd be looking at Wharfedale 9.1 or 10.1 - fabulous speakers and match with any budget system. Going a bit higher in quality terms you've a choice of EB1s, Epos M5is or M12is. Floorstanders terms, look no further Focal 714V (£600 approx), KEFs which are sold at Richer Sounds....
Do you mean the Wharfdale diamond 10.1
like these
http://www.richardsaudiovisual.co.uk/av/warfedale-diamond-10-1.htm
