What speaker setup in this outside place?
jayukguy147
46
7
545
This is my new house that came with this nice bar. I have a Fyne audio F502SP inside in a dedicated room.
I'm looking to add some speakers within the bar, for chilling with herb and whiskey :)
I do plan to add a TV at some point, so can a soundbar do well with stereo?. I use Tidal Master
Please see pictures
camcroft
Please see pictures
It could depend till what time ( At Night you want to play them ) Very close to neighbours or can I suggest buying ear defenders for them. Lovely space you have there.Enjoy whatever.
I believe there are quite a few designs made for poolside use etc., but they don't often appear in hifi journals.
Does something like this appeal?
Witterings
I used something like these for 15 years and they were great until they eventually gave up on me
https://cpc.farnell.com/apart/rock-...4517&s_kwcid=AL!5616!3!605262956605!!!network}!1677584189002!&gclid=Cj0KCQiA_P6dBhD1ARIsAAGI7HAtljsMkt_sRruB3LgOnB6TRC-PmPYttlEvNBylYXB-wJbX869ppJ0aAoFQEALw_wcB
I replaced them about 3 years ago with some of these which are brilliant
they do a Apart mask 4 as well which is smaller, I only went with the 6's as my amp's 130 watts and outside sound disappears so the more air you move the better ... although it sounds like they're going to be in the room whereas mine are just outside.
They come with wall mounts you can easily remove them from for winter storage if you want, if I'm hones I'm too lazy and do use them in the winter sometimes as well so they stay out year round.
