- Aug 10, 2019
- 2,556
- 5
- 0
just bought a cyrus 3 and have been poking the wires in the sockets. I bought some standard banana plugs and they dont fit.
What do i need?
What do i need?
Oozed said:I guess you'll all have sold your Cyruses by now, but if not ...
Mrs Butcher I guess will need MFA plugs.
Those of you lumbered with 3mm speaker sockets, best solution might be to replace them with the 4mm equivalents, available from Farnell for under £2 each.
http://uk.farnell.com/deltron-emcon/571-0100/connector-pcb-2contacts/dp/1494595 (black)
http://uk.farnell.com/deltron-emcon/571-0500/connector-pcb-2contacts/dp/1494593 (red)
These are Deltron parts, just like the originals. Don't get the cheaper suffix -01 variants, they're tin-plated.
The Cyrus comes apart pretty easily and changing the sockets is a straightforward affair.
John Duncan said:How very dare you.
http://www.whathifi.com/blog/replace-the-hard-drive-in-your-imac
MajorFubar said:(With my cap duly doffed to the precious few of us left on here who don't mind popping lids and firing-up the soldering-iron).
