CnoEvil said:Jason36 said:Personally I like a lot of detail with my music, which is probably why I now do most of my listening via headphones![]()
Ah, but you are also a "vinyl junky". :shifty:
Sweet! Got him in the (hidden) detail...
paradiziac said:My 10p:
A hifi that lacks detail can still be musical, a hifi that lacks character isn't musical however much detail is on offer.
Alantiggger said:''
Detail is simply a lack of distortion and is quanitfiable, character, on the other hand and other often used adjectives, such as musical, are largely meaningless.
Could you possibly expand upon what you mean by 'lacks character' and 'isn't musical' ? Charcter has been used in the OP, but no-one has yet explained what it actually is.''
____________________________________
I'll go along with this .... my whole set-up is just less than three grand .... but this fellow sounds on the ball.
altruistic.lemon said:I doubt Elgar intended his "Requiem" to be fun, so any hifi equipment that added vitality should be avoided like the plague.
paradiziac said:Without getting too bogged down in the definitions, I'd equate character/musical/fun.
I think some folks are taking "character" to mean "system-added colouration", but I don't believe this was PP's meaning.
For example, some systems just let you enjoy the music and make you want to keep listening, and some systems are boring.
Specifically, if a system has poor timing (e.g. musicians sound drunk when they weren't!) or poor dynamics (lack of contrast between loud and soft parts), it's going to be a boring listen, EVEN IF the level of detail offered is forensic. The only case where a person would "enjoy" such as system is if they enjoy listening to hi fi and not to music.
So my vote: character first, with as much added detail as I can afford!
Perhaps we should rephrase the question:
Visceral or cerebral?
paradiziac said:Specifically, if a system has poor timing (e.g. musicians sound drunk when they weren't!) or poor dynamics (lack of contrast between loud and soft parts), it's going to be a boring listen, EVEN IF the level of detail offered is forensic. The only case where a person would "enjoy" such as system is if they enjoy listening to hi fi and not to music.
AKA cello concertocse said:altruistic.lemon said:I doubt Elgar intended his "Requiem" to be fun, so any hifi equipment that added vitality should be avoided like the plague.
I hadn't realised that Elgar had composed a "Requiem""???
plastic penguin said:Likewise, the DacMagic exhibits the same traits: This detail, clarity, openness translates, on my system, into a cold, mechanical sound.
plastic penguin said:paradiziac said:Without getting too bogged down in the definitions, I'd equate character/musical/fun.
Right, let's get to the bottom of this before any additional confusion.
Given I have the DacMagic, listen to freeview commercial radio stations, heard one or two amps that don't quite measure up, reviews that ram the "detail" down ones collar when components are rated etc etc... I've absolutely nothing against detail, transparency but found IMHO that the freeview stuff increases detail and openness but loses out in terms of emotion, soul. Likewise, the DacMagic exhibits the same traits: This detail, clarity, openness translates, on my system, into a cold, mechanical sound.
Whether one relates to warmth as the aforementioned flipside, that's down to the individual but the more I hear the newer modtech - albeit I'm still cutting my teeth with the streaming option - the more I'm disappointed.
For some reason, this is a personal psychological block, the more the detail the higher the risk of losing that precious commodity - Fun!
Overdose said:Are you suggesting that some equipment, somehow changes the musical composition?
Overdose said:This I really don't understand. I also put timing in the same box as rhythm and pace, along with fun and toe tapping. I get my enjoyment from my music and do not try to listen for any particular nuances, indeed I don't have to, as I find my system is quite resolving, not perfect, but good enough for now.
BenLaw said:Well the 'modtech' you describe is budget and, if Craig is right, deficient, so I don't see how you can draw any general conclusions. Plus, as I commented before, the fact that the title to your thread only addresses detail makes me think that in your head it is 'detail vs character'. Well it's not. You can get kit that covers both, albeit one is deeply subjective.
I disagree. Lack of distortion is called accuracy in my book, detail involves much more than that: it requires a volume balance over the frequency range that matches the speakers and the listener's ears, so as not to drown out certain sounds. It also requires a lot of headroom in the amp to compensate for sometimes erratic impedance curves of speakers. Regardless of whether you think subjective qualifications are meaningless, I find such characterizations helpful, much like "house sound" helps me to build a shortlist before auditioning.Overdose said:Detail is simply a lack of distortion and is quanitfiable, character, on the other hand and other often used adjectives, such as musical, are largely meaningless.
For me, an amp that 'lacks character' is an amp that fails to deliver detail in the midrange (the vocal range). Whether that is because of distortion, a speaker mismatch or frequency imbalance doesn't really matter, the result is a lack of emotion (and immersion) in the music. But I guess that definition kinda defeats PP's original dichotomy 😉Could you possibly expand upon what you mean by 'lacks character' and 'isn't musical' ? Charcter has been used in the OP, but no-one has yet explained what it actually is.
Craig M. said:plastic penguin said:Likewise, the DacMagic exhibits the same traits: This detail, clarity, openness translates, on my system, into a cold, mechanical sound.
pp, i don't think the 'detail, clarity and openness' is translating in your system to cold and mechanical, i think the dm is cold and mechanical, full stop.
