Animesh Ghose said:
Andrewjvt said:
With most things written on this post from all the others but in my case changing from the same make amp 150w to the 250w amp made an overall improvement to the sound from the top end and mostly the bass
so you are saying if i was to swap evo 50 a to a 100a and play the music at same volume level, the SQ will be better?
Going back to my originan question: does more power mean louder or better overall performance too?
More power always means louder, but not always better performance (either from the amp or speaker side). Certanly no speaker performed worse for having more amplifier headroom, but many (if not most) will be bottlenecked by the amp. Whole different matter is if we can't hear the limitation (in peaks) or if we think the deteriorated sound comes off as improvement and higher fidelity. Distortion in certain forms can come off as richness, texture, musicality etc.
Two possible conclusions:
1) Watts are cheap, better have more than less.
2) If you think the Earth is a disc on top of whales, better stick to less watts and enjoy musicality. Less is more. *bomb* *angel*
