what integrated with B&W CM-7 speakers
my home theatre is denen 3808 AVR,Oppo BDP and Bowers & Wilkins CM 7 speakers. would like to run them with a stereo integrated amp purely for music occasionally, Please suggest an amp and how to connect it. not too expensive(average priced) amp
dr.suze:my home theatre is denen 3808 AVR,Oppo BDP and Bowers & Wilkins CM 7 speakers. would like to run them with a stereo integrated amp purely for music occasionally, Please suggest an amp and how to connect it. not too expensive(average priced) amp
I'm waiting to read the replies to this one too
I used to own CM7s and I thought they sound fantastic with my NAD C355bee. Highly recommned this combination. To me, the CM7s could sound a tiny bit bright if paired with the wrong amp. The NAD has a warmer sound which I found to be just right with the CM7s. If you want something slightly higher up the food chain, then I'd be considering a Naim nait 5i.
Not sure how it is in the UK ,but B&W's are often paired with Rotel gear here.I have heard the CM7's with the new Rotel RA-1520 integrated, and it was a good match.I believe it received a 5 star rating in What Hi-fi recently as well.It is well damped and will provide good control over the low frequencies of the CM7's, and has a smooth top end which imo is essential for the unforgiving B&W tweeters.
I would avoid roksan as they make music tiresome with the CM7's. Best going for a warmer amp, for example Nad as previously said. I went with the Yamah A-S1000...smooth and warm, therefore give the yamaha a-s700 a listen. These amps are very easy on my ears, so you can sit back, kick your feet up and enjoy the music
