CnoEvil said:No, I'm afraid I haven't. I believe they are very clean sounding, which can tip into brightness if wrongly partnered....if memory serves, FennerMachine used to have some, but replaced them with Spendor SA1s.....I think they were too forward when partnered with Cyrus.
My advice would be to stick with what you can demo....the choice isn't too shabby if you are prepared to do a bit of travelling.
David@FrankHarvey said:I'd say you'll need to be looking at something like the Sonus Faber Toy Towers at a minimum, but of course, they're going to sound different being from a different manufacturer. I found the Q Acoustics Concept 20 to sound similarish, and about as close to an LS50 you'll get at the price, so you could try out the Concept 40 - obviously it won't have the benefits of UniQ - worth a try. The R500s using the "half bung in the top port and a full bung in the low port will get as close as you're likely to get I think.
Prolle said:Think I will jump in the car in the morning. Would Kronos have the largest selection of floorstanders on demo in Northern Ireland?
