steve_1979
SpursGator said:It's a great question, but an even better one would be, why use a standmount at all, especially a chunkier one that needs a heavy stand? A floorstanding speaker that is the same size as the standmount, but extruded all the way to the floor, will take up exactly as much space and will outperform the standmount every time. So why do people buy standmount+stand despite no advantages? It's got something to do with WAF but like most things related to that, makes no sense at all.
Floorstanders are usually capable of reproducing deeper bass frequencies than stand mount speakers thanks to their larger enclosure volume. But stand mount speakers often have advantages in other areas.
Stand mount speakers tend to have a better stereo image and while the bass isn't a deep it is often better controlled. This is because the large enclosure surfaces in floorstanders create more internal standing waves which can make them sound a bit boomy by comparison.
There are pros and cons to both types of speaker.
