What Happened to Squash Balls
pwiles1968
153
WHF use to have tips for improving Fidelity on the cheap, one of them was Placing 1/2 squash balls under your CD player to absorb vibration, Do not see this being reccomended much is that because of the cheap availability of things like sorbothane feet is this still the done thing?
I Still have my 1/2 squash balls under my CD player
SpiceWeasel
189
Which "dot" is the best to use?
Im thinking of using a few balls cut in half to insulate my centre speaker from the glass top shelf of my new tv stand (delivered last week but still in the box waiting to be assembled, had a bad case of the flu for the last 9 days).
Bodfish
16
I think the weight of the component in question will have a bearing on which dot
pwiles1968
153
I asked for the softest option in the shop, From memory you need the slower ones they are soft.
ColourSpeedBounceDouble YellowExtra Super SlowVery LowYellowSuper SlowLowGreen or WhiteSlowAverageRedMediumHighBlueFastVery High
a91gti
28
Thanks for that but I reckon I'll be sticking to sorbothane feet if required. I'd only lose fingers cutting squash balls in half. Oh, and spend too much time worrying that I hadn't cut them precisely!
