What Cables and wires ? Quick help needed
Im buyig the below and have got lost in the amount of choice there is for wires an cables. Basically i haven't got a clue what i should be buying.
Could someone please tell me what exact cables i need to hook the below up together. I have included the link from the site i am buying the speakers from which gives options. Thanks in advance.
http://www.hispek.com/P/Kef-KHT20053SILVER-Speakers-System-in-Silver(KHT20053SILVER).aspx
Sony KDL - 40X3500
Blue Ray player - Panasonic DMP-BD55 £369
Reciever /Amp - Yamaha DSP - AX863SE £600
Speakers - KEF KHT 2005.3 £700
HDMI from the BRP to the AV Amp
HDMI from the AV Amp to the Telly
Speaker Cable for the AV Amp to the Speakers.
Or did you want make and model?
HDMI - current mag favourite is van den Hul (Flat)
Speaker Cable - current mag favourite is Chord Carnival Silverscreen
Or for the speaker cable you could go for QED Silver Anniversary Speaker Cable (available on the page you linked to).
To save money you could consider using either of the speaker cable options I've just identifed and go for a cheaper cable for the two rear speakers, like QED Original Speaker Cable for instance.
Oh, and does the Kefs come with a cable for your sub? If not, you'll need one to connect your sub to you AV Amp. Recommend that you don't spend too much money on this cable unless you really want to.
And you might want to consider buying fancy power leads. I'm not sure I can tell the difference with or without them to be honest. But I got a couple of the Tacima CS929 (they were going cheap) and they offer surge protection.
Thanks for your help.
My god surround sound is complicated and expensive - starting to feel that i should have gone for an all in one system
hi have u tried mark grants cable website excellent quality and price to match,check his b-products as well,hope this helps
elstimpo:starting to feel that i should have gone for an all in one system
When you watch your first film, you'll be so glad you endured a little bother and you won't regret it for a second.
