Wall Brackets - best retailer and advice please
Oldboy
421
Hello,
I've been looking to buy a fixed wall mount for my new Sony KDL40EX503 lcd and have been shopping around on the net all morning getting confused with the sheer ammount of retailers and different brackets available....what i would like to know is if anyone can recommend a good retailer and what should i be looking for?
For example what are the pros and cons in buying a cheaper bracket (£30 - £40) as opposed to spending a bit more, say £50 - £100? I was looking at getting the proper Sony bracket untill i saw the price, £146 on Ebay and £249 new from retailers....ouch! So now i'm looking for an alternative and any help would be much appreciated thank you.
I bought mine from http://www.av4home.co.uk. It was a premier mounts product. I am very pleased with both the supplier and bracket. If you mounting high up, a tilting bracket is worth the extra - I would get reflection from my ceiling lights without a tilting mount.
