Volume Controls on Yamaha AV reciever
Hello All,
What are the ideal volume control settings for the centre, front L & R and the rear speakers in a 5.1 set up on a Yamaha
RVX 2400 AV Receiver
Cheers :clap:
sta99y
137
cwalduck said:
Use the microphone and run the calibration routine, that would be a good place to start :?
yep as above, then tweak to you're own taste.
i have same amp and know it inside out.
What is the procedure for adjusting the amp using the microphone. Can you please provide me with a step by step guide
Kawal
